Hello
That's been 18 years ago that I had replaced a magnetos on a Lycoming airplane made homebuilt ignition, with automotive components coil dual Ford module, Honda MPS 205 driver by a magnetic coil pickup, no moving part. it worked very well without maintenance.
But I would like a high energy system by retaining the most magnetic (most modules present its haf effect)
I am looking for module ignition
Bosh 9222 067 021 or 922 067 024
or an intelligent high energy module substitute vari-dwell
I would like to know which car has these modules
Former 9222 067 021 module I'm looking for
Currently I found two Bosch module 0 227 100 123
who was going on Peugots I do not know if it is intelligent modules varidwell and also controllable by a magnetic coil pickup without going through a computer?
ignition module
- elephant
- Registration: 28/07/06, 21:25
- x 7
Out of curiosity:
you do not have to use aviation certified gear?
elephant Supreme Honorary éconologue PCQ ..... I'm too cautious, not rich enough and too lazy to really save the CO2! http://www.caroloo.be
Hi Andrew!
Here is the list of the ignition modules and the manufacturers who use them:
http://www.spectromatic.net/old/spectro ... index.html
The 0 227 100 123 is not there but here are the cars that use them:
http://www.autopartoo.com/oem/bosch/0227100123vqg.html#
This module does not work directly on the pickup coil but must go through a MegaSquirt-II which is an ECU.
http://megasquirt.free.fr/sources/MS/ma ... ch_124.htm
See you!
See you!
Stepping behind sometimes can strengthen friendship.
Criticism is good if added to some compliments.
Alain
Alain
Hello
thanks for the information
For the 021 module and 024 simple installation, I saw that it is Mitsubishi and Nissan that uses this module (rather old) I will focus my research.
For 123 I tested it with a magnetic pickup signal on a test bench I found that the function vari dwell was not operational.
Definitely it will be necessary that I go with an affefect if I want to have more recent meteriel, that will ask me modifications
at the level of the sensors ..
For elephant in amateur construction you have a certain latitude on the pieces and equipment such as battery starter alternator GPS ect .. (although without being ultra conservative and working with magnets with points, it is possible to improve with an electronic ignition high energy (To keep some security I keep a standard magnetos)
Andre
Andre
André Good evening!
It is possible to make a small assembly with a transistor to operate this module but the advance of the fire will not be variable depending on the acceleration because there is no TPS (Trottle position sensor) or MAP sensor and I would not dare to install this on an airplane for flight safety.
On the other hand if you want a more powerful fire you can use a coil higher in voltage, you can find it in all the suppliers of performance parts like for example an Accel coil, as for the variable advance as this Is not a car where we use very variable diets the piece that you use currently in my opinion is very good for your use!
The other solution for a more powerful fire is to use a Champion Copper Plus Candle which according to my snowmobile tests performs better than the NGK on a mixture too rich and clogs less quickly. massacre)
Alain
Alain
- Similar topics
- Replies
- views
- Last message
- 2 Replies
- 9634 views
Last message by Christophe
View the latest post
14/02/07, 10:24A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : Google Adsense [Bot] and 110 guests
