Since the arrival of winter, I have noticed an invasion of mosses on the very sheltered side and on the asphalt of the "parking lot".
In my research I noted several solutions:
- bleach diluted with a sprayer (see)
- copper wire (my gutters are zinc ... ouch!)
- other magic solutions?
Do you have any advice ?
Foam on bitumen and slate!
Hello buzz569
For copper wire, there is no problem. It is not with the current that will pass between your wire at the roof and the gutter at the bottom of the roof that will eat away at the metal.
For the foam on the sidewalk north side, I have the same problem as you. And I don't know how to do it without using strong chemical etc ...
Reason is the madness of the strongest. The reason for the less strong it is madness.
The fixing does not pose any particular difficulties but depends on how your made, tiles, slates etc. There is no particular effort on the wire, lots of different solutions are good. you can put a piece between the tiles, slates and twist on what you find. For my part, the cement of the ridge tiles had enough roughness to curl the copper wires so that it could hang under the ledge, then stretched on the other side by gently twisting with pliers.
If it's the aesthetic side that makes you sad, don't worry, from below you don't see much.
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 5286 views
Last message by Christophe
View the latest post
05/07/15, 00:41A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
- 11 Replies
- 87948 views
Last message by Bearpanda
07/02/16, 15:31A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
Back to "Sustainable consumption: responsible consumption, diet tips and tricks"
Who is online ?
Users browsing this forum : No registered users and 141 guests
