hi everyone and happy new year
lying subject title
I am looking for a woodchipper that can pass a diameter of 40 cm and the price of a new one is 100 euros, used is 000 euros, a little expensive for me ...
pit mix do you have an idea for less ?? thank you
Search found 101 results
- 12/01/11, 19:01
- Forum : Your technical assemblies, DIY, innovations and self-construction: making an object or an installation
- Subject : Making a mill plant for € 0
- answers: 20
- 17/10/09, 19:37
- Forum : Failure, troubleshooting and repair: repair yourself?
- Subject : ECS wood boiler Buderus Logano problem S121
- answers: 5
good evening, This is often the case with wood boilers, apart from a bad connection on the circuit, check the outlet temperature of the buffer tank? the temperature must not be higher than 80- 85 ° otherwise it is the regulation on the burner which is too energized it is absolutely necessary to reduce ...
- 29/11/08, 17:10
- Forum : Innovations, inventions, patents and ideas for sustainable development
- Subject : Worcester wheel
- answers: 340
- 03/12/07, 19:21
- Forum : Heating, insulation, ventilation, VMC, cooling ...
- Subject : anti-renewables heat pump? Disadvantages and advantages
- answers: 134
- 03/12/07, 19:00
- Forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- Subject : Wood pellet boiler
- answers: 19
- 03/12/07, 18:52
- Subject : Wood boiler: blue flame burning pictures
- answers: 8
- 03/12/07, 18:43
- Forum : Electricity, electronics and IT Hi-Tech, Internet, DIY, lighting, materials and new
- Subject : A house under an electric pylon?
- answers: 18
- 02/12/07, 12:00
- Subject : Pictures and prices of our boiler installation wood stove
- answers: 34
- 24/11/07, 07:56
- Subject : Schematic wood boiler for DHW and heated floors
- answers: 90
- 07/11/07, 19:02
- Forum : Water injection in heat engines: information and explanations
- Subject : Pantone Article in Science and Life November 2007
- answers: 173
hello, it will be interesting to know the cons of the DS, I have an uncle who had one at the time in Geneva and who said that it consumed very little 4 or 5 liters I think For the mercos 190 D, it There are two engines 2 liters atmo and 2,5 liters (turbo?) I have at the bottom of the garden a two liters, ...
